New electric crankcase EVAC vacuum pump
Steve
I have a new electric crankcase EVAC vacuum pump that I would like to sell. This is a LS1 smog pump that is commonly used to pull a vacuum on the crankcase at WOT to prevent oil lieaks from crankcase pressure. There are some good write ups here on the board about installing these pumps and Racetronix makes a nice plug and play harness that kick the pump on whenever you are in boost. $85 shipped in the 48 states. Please add 3% or send as a gift if using paypal. Thanks
It is the 12568324 version with the 2 wire black connector. I will check the part number actually on the unit when I get home today. I believe the pump itself has a Borg-Warner part number also which may be the original supplier.
