buickturboman
- Mar 21, 2004
After installing new: EGR Sensor, MAF, Plugs, Wires. Coil Pack, fresh gas, computer and chip swap, throttle body sprayed out, I am still having a problem with the car stalling at idle, hesitating when not stalling. When it is idling, I noticed when it did idle and I moved the computer, it started to break up and run rough a bit so obviously I have a problem here. I assume after time and removing the computer, replacing chips this was to be expected. Now is the cause of everything going on, not sure yet but I wanted to ask if you guys think I should drop $45 and buy the new ECM plus with the 6" soldier tinned wires Postin sells and go wire by wire and cut and soldier a new plug using shrink tube afterwards?
I got an insulated ECM cable for my Direct Scan but that isn't even coding any problems. I think I figured out why is was coding a lot of strange stuff all at once at times which I believe it was my computer interface cable (not ribbon cable) was pinched sharply and when I straightened it out, these trouble codes disappeared.
Anyway- please advise me on this ECM plug replacement if you giys had similiar probs and if you replaced it successfully....advice.
I am not Joe mechanic here and know nothing about these DFI I guess they are called. If someone had the bucks to buy the Fast engine control system, would it eliminate all the stock computer and eliminate this wire harness problem I am having?
