I just installed the alcohol set up and I used the harness that goes from the new 3 bar map sensor to the TPS sensor and I ran the green wire from that under the dash to PaC 6 wire harness since I hoped that up I do not get boost or map pressure on my ScanMaster what do I tap or connect into so I can get these readings Thanks
