NEW 160 LB/HR LOW-IMPEDANCE FUEL INJECTORS (E-85)
Racetronix
NEW DESIGN 160 LB/HR LOW-IMPEDANCE INJECTORS
These new low-z fuel injectors are the perfect step between our 120 and 220# models.
Unlike the old Bosch 160# LPG injectors which were not a true low-z injector, these are.
The 2-ohm coil allows for full peak current and maximum field saturation using P/H drivers.
Faster and much more linear than the old models even at elevated pressures.
Going E-85? No problem! These are 100% E-85 compatible and sport stainless bodies and Viton o-rings.
http://www.racetronix.biz/itemdesc.asp?ic=01D164x&eq=&Tp=
Limited introductory pricing and supply.
These are made by Standard Motor Products (same people who make the Delphi 42's, Trick Flow, Accel, RC injectors)
We have dealers who have been testing these injectors for two years now. Eric @ TT has done some work with them and may have a chip available.
