NEW DELPHI 17113738 50lb/hr FUEL INJECTOR
blownbuick
NEW DELPHI 50 LB/HR FUEL INJECTORS
Part Number 17113738 (OE # 17104487)
Same injector as MSD 2013 injectors
Discontinued by Delphi - Get them before they're gone!
Set of (6) - $269 shipped in the 48 states if paid by USPS money order or PayPal as a gift. $279 by standard PayPal.
Specifications
Static Flow Rate: 50.0 lb/hr @ 43.5PSI (300kPa) 525cc/min or 6.4gm/sec
Static Flow Rate: 57.7 lb/hr @ 58.0PSI (400kPa) 606cc/min or 7.4gm/sec
Dynamic Flow Rate: 1.1 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI (300KPa)
Dynamic Flow Rate: 1.3 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 58.0PSI (400KPa)
Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Cone Spray Angle - 22.4 degrees - Single spray cone. Approximate cone angle for 90% of spray volume
Ball/Seat Design with 6-Hole Diffuser Disc
Flow tested by Delphi to 2% tolerance.
