Need Your Help
Rick
Senior Member
Only one week left if you want to buy tickets for the TurboBuick.Com Raffle via Paypal, check or money order.
Even if you buy only one ticket you'll have 12 chances to win!!
We will also be selling the tickets at Bowling Green up until the drawing on Saturday. For more details see Sticky: TurboBuick.Com BG2002 Raffle in the Lounge.
Let's sell 200 tickets this week!!!
1) Paul Rogowski at SE TURBO Prize Kit:
1 set of head gaskets part # 9441pt
1 set 100 lb valve springs
1 set aluminum bumper struts
1 dual pod "a" piller gauge holder
and Billet Shifter Handle provided by Mark Hueffman.
2) PTE 70mm Polished Upper Plenum By PTE $170
3) Chuck Leeper Injector Cleaning Service Valued at $85 and IMM Console Riser $85 Total Value $170
4) IMM Custom Trunk Kit $150
5) HR PartsnStuff $75 gift certificate and Poly Trans Mount $74 Total Value $149
6) CAS Billet Fuel Pressure Regulator $99 and Jay Jackson 62/65mm Throttle body/upper plenum modification (performed on winner's TB/upper)
7) Mark Hueffman Chrome Big Mouth Cold Air System $185 and Chrome 3" MAf Pipe $60 Total Value $245
8) The 2004r Performance Center PTS XtremeDeep Aluminium Transmission Pan and sump $249.99
9) PTS Xtreme Adjustable Servo Pin $24.00, PTS Xtreme Band Anchor 300m $24.99, PTS Xtreme Billet Servo $169.99, and Alto H/D 2 3/8 Band $39.99 Total Value $254.97
10) SMC Alky Kit $350.00
11) Maxeffort 8 Position for 38# Lucas Injectors $260
12) Alto USA - Red Eagle H/P Clutch Kit (contains 4 FWD red clutches w/steels, 6 direct red clutches and steels, Overrun 2 red clutches and steels, OD 3 red clutches and steels, 6 LR red clutches and 8 steels) - $165
Raffle tickets can be purchased for:
1 @ $5
5 @ $20
Absolutely...............................NOT!!
Good Try though and good luck with the tickets you bought!! :D
