Hi, I was told that for my setup with the stealth 70mm turbo (big shaft standard bearings) I would need a 3400 to 3600 stall. Well I had a convertor made from a guy I know locally. It is a 9.5" convertor in a T.H.350, and I have the car up and running and tuned to 18PSI boost the data logs show the following:
with transbrake and tps at 42% and 3.7 psi boost= stalls to 3800rpm
with transbrake and tps at 82% and 9.4 psi boost= stalls to 4100rpm
with transbrake and tps at 84% and 11.1 psi boost= stalls to 4800rpm
with transbrake and tps at 81% and 12.9 psi boost= stalls to 5000rpm
when driving and I stab it and boost goes to 10psi the rpms are never below 4800 rpm in any gear.
How much should I tell him to tighten it up? I am thinking on the transbrake at 12 psi boost I would want to be at around 3500 rpm. What do you think?
Some additional info (can be found in sig but related to this post)
At 15psi boost ran 11.7 at 117 with 1.64 60'
28x11.50-15 hoosier quicktime pro
3.50 gear ratio
Have not weighed yet but it should be around 3200 LBS.
Is a hybrid 1963 chevyII
Thanks for any info, James
3.50 gear ratio
