I've owned my Buick for the passed 15 years. Did some work to it, it has sat for the passed couple of years, and now starting to work on it again. I meet a guy who has a 10 sec Buick and asked for some advise. I told him my set up and my goal and he made some recommendations and would like some opinions.
First, my goal is mid 11's. The motor and tranny has been rebuilt. Here is the main stuff that I have: TA 60, 36 lbs injectors, Dutweiller neck on stock intercooler, SMC alky kit, 3" down pipe and 3" exhaust, LT1 MAS, Reds fuel pump and I was told 373's in the rear. Turbo Tweak chip was recently installed. Car recently ran 12.6. prior to Turbo Tweaks chip. Prior to the Large turbo, 3" downpipe and LT1 MAS, car ran 12.0. I thought I was going to get into the 11's with the new set up and I was wrong.
I am now being told to change the gears to 3:42's or 3:23's from the 373's. Is this recommended?
I was also told to get a different Alky set up. Would this make a difference?
Lastly, I was told to get 60lb injectors? My car does not run lean and I do not get any knock at 24 lbs.
I know you will probably need more information, but any advise is appreciated.
I'm not sure if I should spend over $1,000 to change my car when I believe that I have a good enough set up already to reach my goal.
