Hi,
Code 12, while the car isn't running, means nothing more than that the ecm is not receiving an rpm signal. This is normal.
Our cars are pretty notorious for no start issues, and you have to begin by checking the obvious stuff. When you turn on the ignition, do you hear the pump run for a couple of seconds? If not, you have a fuel problem. Next, take a plug wire off,check for spark.If you have spark, you are probably dealing with ecm issues. I would bet you have no fuel pressure, but what do I know? We could go further, but I think you should check the basics first, to identify the area you need to search.
