Ok, first off the car just needed charged and it started up.
Second the shifter light does work and I haven't found any blown fuses. The shifter light's power wire was cut so I did fix that to make it work before I hooked up the switches.
My nitrous switch has been there for months. I just added wire onto the existing wire and ran it to a different switch located in the ashtray so I haven't added anything new except the tcc switch and it works fine, thats what I don't get. I didn't mess with the fuse box or any other wires, just cut the existing and added more wire to it. And the previous switch had a ground so I am assuming that that isn't the problem but I have tried it without though.
I have disconnected everything I did and no luck. I put direct power to the switch and no light comes on, I put direct power to the glove box and nothing happens. While the car is running the right turn signal flashes off (stays on b/c of a burnt out park light that has been that way for a month or two) and comes back on and does it intermittently. I would think that putting a direct power to the switch or glove box would do the trick but it doesn't. Does this sound like a bad ground to the fuse box and would a bad ground cause all these other things to happen like my passenger side lights not coming on when I turn them on. I tried taking the fuse box out by removing those 2 bolts but it won't come out. Thanks for the help thus far, anymore would be very appreciated.
