Well the car went back on the road yesturday and I'm in the process of tuning it up. I've been trying to figure out a tip in throttle stumble for awhile, but I waited until I got some scan tool #'s to post. I hooked the scan tool up and check IAC and TPS. TPS was at .55V at idle and IAC is in the mid 60's. I set the TPS to .38V at idle without any problem. The IAC however is a different story. I tried both methods of resetting the IAC on gnttype.org and neither worked. Adjusting the minimum air rate on the throttle body only gets a lowest reading of 58, after that the rpms get too high for idle. So I tried the GM service manual method. With the IAC unpluged it idled at 2400 rpm. I dunno whats going on. Any help is appreciated.
Thanks,
Thanks,
