Starting at the beginning. I purchased a 67 mile TTA a little over a year ago and i'm still chasing a starting problem. The car had a knock at boost over 8psi. I was able to enlist the help of a local turbo buick expert. After testing for codes and finding none, we replaced the fuel filter and injectors. After installing the injectors, the car would not start. Fuel pressure was good,regulator was not stuck and nothing else seemed to be at fault. Out of the blue the car started and ran ok with no knock. Problem solved? Not so luckey. Jump ahead a few months to the night before the TA nationals. The car decides to not fire. As before it cranks fine but does not fire. I tried replacing the coil pack, ignition module, and ECM with known good units and no change. Each done as single steps to pinpoint the results. I also replaced the VATS module. When it cranks without firing, if I pull the ECM fuse and put it back, the car starts. It may start 5-6 times before deciding not to fire. HELP! When it does start, it's only after cranking for a few secconds. Any help would be greatly appreciated. Thanks, Steve
