Possibly for the illuminated trim plate. Gray is typically a dimmer voltage wire with the other being a ground. See if the voltage on the gray wire varies as the dimmer switch is rotated. If so, it may be that, or it may go to the HVAC head.
RemoveBeforeFlight
