I am wanting to learn to properly tune my 86 T-Type via factory ecu. I have a few questions I can't seem to find the answers to. What all is need to get started datalogging? I am ordering an adapter for the ecm so that I can use the newer reflashable eproms. I already have a Burn1 chipburner and a WB o2. What cable do I need for dataloggong? Is there a shareware program out there for this or do I need to buy one? Also, is there a program that will handle datalogging and also pull up bin files and read them in a seperate window so changes can be made on the fly fairly easily? I have had some expierence working with Hondata and Uberdata for Hondas but never with GM.
I have downloaded tunerpro from Moates but I am not sure how to use it yet. Is it a good program and will it perform datalogging? As far as the WB o2, the one I have is the diy one I put together which seems to work fine. Can I take the voltage out from the sensor controller and run it back to the stock o2 sensor harness, back to the ecm, and data log AF straight from ecm? Sorry for all the questions, I just need to be pointed into the right direction.
