Yea, waayy too much converter for the stock turbo. Less converter and more turbo and more boost and the recipe is there. ks
Too much converter for the stock turbo, I doubt that? But to solve his problem there needs to be more air flow which requires a larger turbo.
He is set to run tens with a 60 or 61 turbo and 116 octane race.
A local GN with a very similar build of his and what I stated, has run 10.90 with an engine that only had the timing chain and valve springs replaced, heads have never been removed. Converter is a 3800 stall and a TE-61 old-school turbo.
Another important add-on was a double pumper and the PROPER wiring to assure adequate fuel was being supplied.
So what I need to do?Yea, waayy too much converter for the stock turbo. Less converter and more turbo and more boost and the recipe is there.
ks
Which turbo..... How much boost?3500 stall and stock turbo? Maybe a bigger turbo and more boost.
Which 60"? N te44 with my mods n 25lbs of boost?A TE44 will go mid 11's with your mods. Boost around 25 depending on your 60'.
My son is headed in the same direction with his set-up. He would like to see an 11.00 slip.Too much converter for the stock turbo, I doubt that? But to solve his problem there needs to be more air flow which requires a larger turbo.
Which turbo n set up I'll need to get a gud misd's 11He's saying your 60 foot times on the track. You might even go a little bigger than the TE44. It takes boost to make it happen.
Which set up Ur son using maybe it can help me...My son is headed in the same direction with his set-up. He would like to see an 11.00 slip.
