need help finding a part.
Their tech guys are friendly and knowledgeable.
They should be able to help, many times they have put me on hold while they check with a manufacturer to get the info I need.
Give'm a try.:)
I tried them and they couldent help me since the manufacturer for that didnt list a part number for that part...
That's dissapointing......
I guess the next move would be to contact one of the TB.com Transmission Vendors in your area and ask for some advice.
Pretty sure they're Female 5/16" Inverted Flare to Male Barb.
Napa, Advance, Autozone etc.. may also have them.
This style will screw into the Rad Fitting or onto the Trans Line Fitting >> Insta-Dapt Radiator Adaptor Makco Transmission Parts
much cheaper here >> DERALE 13004 5/16" Hose to Radiator Adapter Fitting Transmission Cooler
same # here >> Derale Cooling Products 13004 - Derale Performance Transmission Line Fittings - Overview - SummitRacing.com
This style you cut the Fitting off your Trans Line, it uses a Ferrule to seal the Fitting to the Line >> Smart connect fitting for 5/16 lines (2 fittings) Makco Transmission Parts probably not what you want to do.
