brings up a great question. I wonder if it would work better pointing it torwards the ic instead. See the alcohol works by breaking it up in the air stream and having it "flash" into the air. The more we can delay the process the better. This is why direct port doesnt work for cooling the air as it doesnt give it time.
The first injection kits would use a nitrous fan tip nozzle. What was found out was that pointing the fan tip torwards the air.. Meaning against the air.. Worked better at breaking up the liquid.
When we started using the oil burner type nozzles.. The issue was eliminated. And the distribution problem ended. But.. That doesnt mean it cant work.
Brings up a good question.. And as always.. Without data no telling when an idea is an improvement or a hinderance :d
View attachment 151638. designed and built by a good friend . thought he should market this !
Before I forget, Replace the line going to the fuel pressure regulator with a vacuum hose and zip tie it down. The one you have you can tell is being forced and if it pops off or breaks, you'll lose fuel pressure.
Ohhh.. you wanna get snazzzy
I installed a 1/16 npt to -3 adapter and plumbed it to the spacer. Top that one
Yea but my regulator is powder coated
Brings up a great question. I wonder if it would work better pointing it torwards the IC instead. See the alcohol works by breaking it up in the air stream and having it "flash" into the air. The more we can delay the process the better. This is why direct port doesnt work for cooling the air as it doesnt give it time.
The first injection kits would use a nitrous fan tip nozzle. What was found out was that pointing the fan tip torwards the air.. meaning against the air.. worked better at breaking up the liquid.
When we started using the oil burner type nozzles.. the issue was eliminated. And the distribution problem ended. But.. that doesnt mean it cant work.
Brings up a good question.. and as always.. without data no telling when an idea is an improvement or a hinderance
The braided hose will rub of the paint on the IC. make a spacer using another zip tie in between the hose and IC.
I dont quite understand all the spacers used for attaching the nozzle to the new welded section. Dont know if thats a check valve after the 90 elbow or a 1/8 coupler.
When I had engine work done last year, had the Alky Kit installed and the nozzle is underneath the up pipe and close to the IC. The car runs great with the nozzle in this position and hidden away. I haven't taken it to the track but it is running strong with "no knock".
The issue with hose height has to do with siphoning. If you mount the nozzle tooo low it can drip drip drip when you shut the car off as the liquid inside the tank will be way hgher.
Ohh.. time to update those hose clamps on the pressure side to T-Bolt.. so you dont pop off a hose when getting into higher boost. Worm clamps dont hang with high boost.
Thanks for sharing the pic.
Thanks for the tip on the clamps, getting ready to order new t-bolt clamps and new hoses. Here is a better picture of my engine. It was the one with the bad pistons that needed rebuilding last year, ha,ha.
