1. car is still missing it feels like at high rpms mostly into drive and OD shifts.
its not my alky cause it does it when the car is off. i also just replaced the coil pack and ignition.
2. some times i turb the key and it takes like a seconed or 2 before it turns over... is this the precurser to something going bad,, it doesnt do it every time.
3. turn signal is like mad slow like up to 2 seconds between blinks sometimes,left is slower than the right it seems.
update to other problems
1.no longer blowing the ccci fuse only a grounding out wire.
2.clank going into gear and vibrations.
3. replaced the U joints.. one in the front was ok one in tha back had no bearings ground halfway on 2 of the sides,,,, really bad ill take a pic sometime,and replaced the tranny mount all is well.
4. brake lights not working it was the little white wire plugged it back in all better
thanks for all your guys help.
