Hey fogged, did you buy or fabricate your engine mounts? Is your crossover in front of the engine? Do you have the accel dfi?Im puttin a 3.8 in my 2wd 91 s10. Yours looks great, I like the bravada grille.
Doubt I'll make it, the trucks still not finished. Don't know if I'd ever go, driving cross country without overdrive doesnt sound like much fun and I dont own a trailerThat's cool as hell! That's going to be a sleeper. I alos like the Bravada Grill.
It would be cool if you could make it to the Bowling Green GS Nationals, I'd like to see that ride in person. Good luck with it.
Yea its great to see someone break the mold and not do a 350 or 4.3. Ive searched on all the s10 forums and no one has done it. Ive seen a few 3800 engines but no GN engines.
I used factory regal 3.8 mounts. Just inverted them and swapped left to right and right left. If that makes sense kinda hard to explain.
The crossover is custom and runs behind the engine, I have some pics of it somewhere I'l try and post later.
Yes Im using DFI.
Ive seen a few, there was one running around here in orlando a few years back. One was for sale awhile back on this board as an unfinished project.
hey fogged, did you have to do alot of cutting to get it to fit? there is a guy on turbobuicks.com who said he had to cut his firewall and crossmember i think, did you?
the crossmember under the engine. I think he said he had trouble with the oil pan, but i dont think the 3.8 is any bigger than a 4.3. What about running the cross over in front of the engine like the syclones and typhoons? Is there any serious clearances issues in front?
My oil pan clears fine, I might be an issue when I build another motor and use a girdle.
I don't know how you would run the cross over in the front. The ports on the heads are'nt symetrical, so you cant just swap the manifolds from one side to the other. Even if you could it would put the turbo in the fire wall on the drivers side
I figured on having to weld up a set of headers to get it to work. I really hate to cut my firewall or floor pans at all becausei we put alot of time in it, we painted it to match the body. I'm running 17x8.5s in the front so fender well clearance might be an issue. Have you had your blazer at the track yet?
Dunno How close I am really. I still need my turbo rebuilt and to get a drive shaft. I have a list of other stuff that still needs to be done before its drivable.yea if i can cut up a set of manifolds and get them to work i will. How close are you?
