I had a sub-panel fuse block for intalling next to the factory one. I could'nt find a good spot on the interior. Probably to do it the best would be to install fuse panel on the engine firewall or inner fenderwell. I did'nt want to rewire everything that I had previously did, so I got those trick little 20amp fuses with the 7amp blade that swings out and provides a connection spot. Then I just routed the best way I could. Used alot of small zip strips. The fuses are called access a fuse.I tripled up some wires,but I don't think they use much power. Total of 6 gauges,ahlky,boost-a-pump,scanmaster,radar detector,and probably something that I can't rememer.
