Ok so every told me you run 25 lbs of boost on alchy with 26* timing and your gonna blow a headgasket. Well tonite Im not sure if that happened or not. Well I was tuning my car to goto the track tomorrow 25lbs of boost 26* timing I was trying to dial in 27 lbs for the track tomorrow. Well 1st low alchy light came on. I figured ok enough for one last blast to dial in the boost. WOT throttle 25 lbs no knock looking for 27 lbs. Didnt happen. Only goto 25 lbs. Though prior to that it went to 30 a few times but never saw any knock on the scan master as i got out of real quick.
Well I exit off the highway and I can see knock on the scan master any where from 1-12 and on up. I was on the throttle but everytime i put a load on the car or slight acceleration it would show knock on the scanmaster. Ok im off the offramp and I can hear what sounds like a rattle or what might be described as some type of knocking literally. It sounding like something was knocking in the motor. I have my eye on the temp guage and temp read pretty normal 175-185 range. Which I thought was about right for the torture and the several blast i just put the car through. Oil pressure looked ok as well. Well I limped the car home 8-10 miles or so and while driving it seemed the car slightly knock under idle at the light but of course the more load or acceleration you put on the car the louder this knocking sound got. My first thought was a blown head gasket, but the car was leaking anything nor was it smoking. I was thinking maybe or hopefully it was just something loose under the valve cover whic i have yet to take off and see cuz i dont have garage or any good light. Looked under the hood and didnt see any leakage of any kind? Turned the car off and started back uo with no problem besides the strange knocking sound coming from the driver side. Kinda sounded like something was loose in the motor or under the valve covers. Im not sure what it is?
If you good folks would care to share your thought or educated guesses on what it might be so i know where to start tomorrow that would be great. I honestly dont think its a HG but i could be wrong. Sorry bout the long post but i felt the better the description the easier it would be to diagnose. Thanks
