B Blue87T New Member Joined Mar 1, 2003 Aug 16, 2003 #1 Are the mount supposed to hit the block at the top by the freeze plugs? Can't see how they would go anyother way but just want to make sure they arent bent ..
Q Quick6'n'-K.C. wana steal it? meet mr9mm Staff member Joined Nov 24, 2001 Aug 17, 2003 #2 the mounts do go upward toward the freeze plugs and are real close to the block- probably about 1/8th of a inch away as long as the pads arent gouging the block and freeze plug bosses then you should be A.O.K. There is a difference left to right HTH BW
