So im putting on a new trans filter.... and cant get the old orangish rubber ring seal out.... any suggestions? im trying to be super careful and not damaged insides
Use a flat head screw driver. Put the tip on top of the seal and it will easily pry out. Don't worry about damaging the pump because it does not require that much force.
Watch out, those picks can be dangerous.
I have used picks, too. I have also used a 7/16" deep well socket on a long 3/8" extension. I put the end of the socket up into the o-ring and then put some pressure on it while trying to work it down / out of the pump. I was able to remove the stuck o-ring without any problems.
Use a medium flat head screwdriver and push one side of seal up into the pump, it will rotate the seal and then just pull it out. Causes no damage to pump and very simple.
