I was sitting down the other day thinking about how I can space the rear wheels out on my GN. According to some info I found, the GNX's had 8 inch wide rear rims with approx 3.5 inches of back spacing. I know my slicks are mounted on 15x8.5" rims with 3.5" of back spacing. These fit fine and look great.
From my measurements I found that in order for the GTA rims to approximate the same positioning in relation to the wheel lip, I would need a 7/8" wheel spacer with the "front" offsets which are approx 4 3/8" back spacing. Problem is no one makes a suitable bolt on spacer in less than 1" thickness.
What I am thinking is using 2 rear offsets which measure out at approx 4.9" back spacing with a 1.5" spacer (1.4" would be ideal)
which is readily available. What do you guys think?
