more parts i dont need hanging around
nonosv6
just some things im not planning on using that are taking up space . prices are not firm and will consider trades...thanks joel
atr 4 bolt s/s headers w/ egt bungs,wastegate tube
,backpressure port,slightly modified to work with 47/88 turbo,and custom support bracket for
turbo $650 lowered price
msd billet distributor sold
isac alky/boost controller sold
max effort 16pos v7.8 75# injectors $75
green stripe 32# lucus injectors i believe sold
blue stripe injectors $75
TT chip 5.7 42# injectors street 93oct 20*-18* 16#-18# sold
TT chip 5.6 42# street 91oct 19*-17* 14#-16# sold
chip stock injectors street 93oct $20
kenne bell chips hot flash and ul for 50# injectors $30 for both
jay carter chip 50# inj street w/alky 93oct $25
M&A arp head bolts new installed never torqued went with studs $65
6 Abs ram air duct inserts $30 ea
Lower control arms not sure of brand. Very beefy with poly bushings. $100 shipped
Comp eng 3 way adjustable drag shocks $50
Stock up pipe with 2 holes drilled 1top 1bottom $30
2.75" up pipe mint Sold
Ans boost controller old school $40
Stock appearing adj fuel pressure regulator sold
Stock mint original intercooler hoses black with orange inside. $40?
Added some things and updated list
Hi is the 2.75 bigger than the stock up pipe.
If its the same I'll take the 3"
Would u take 30 for weather one?
Stock is 2.5. It's def bigger I just was being lazy n didn't have a tape measure around ill measure it tonite How's $40 shipped?
Yeah I'll take the 3" one. Thanks
Do you happened to have the couplers for stock turbo?
Just to be clear I have 2 up pipes for sale . 1 is stock size , the other is either 2.75 or 3"
The pipe is 2.75" I have 2 transition hoses. 1 is red 1 is blue. 1 is 2.75 to 3" other is 2.75 to 2.5" if. U want both add 25$ if u want one add 15$ they are both silicone. Let me know . I have PayPal pm me for my Paypal address. Joel
more info on the air scoops...size of openings ...front (rectangular) and rear (diameter).
Conrad
