mikeandjen
- Sep 14, 2007
Hey guys,
I have noticed considerably more knock retard in cold weather, especially in initial tip in throttle. I am assuming this is from the cold dense air, and increased oxygen flow. Can this issue be solved by just increasing fuel pressure a couple of pounds? Also noticed a slight boost increase of about a pound or two total so up from 16 to about 17-18. I guess I can dial this down a bit. The only other thing I could attribute to the knock I am seeing, since I can't hear any considerable "pinging" is maybe the louder valvetrain in the cold weather?
Any thoughts?
Also I have noticed a slight miss, at idle. It doesn't affect driveability whatsoever, and acts similiar to a larger lobed cam, cold weather and not having an egr play into effect? I am going to check all plug wires and ohm them, but since no miss whatsoever under load don't see that being a factor,
Mike
Any thoughts?
Mike
