more broken parts pix
SIXBANGR
mean old man
got it all torn down. Was pretty easy, most of the stuff fell out. Already bought a short block. The crank did not break and the bottom of the block is ok. Guess that RJC girdle works.
Massive! Try Lowes & Home Depot for the Contractor size J-B Weld. :cool:
Can you re-use the girdle or is it toast too?
girdle is fine, had a couple dings in it. The crank is no good, got hamered , just didn't break. The parts are 2 pistons, crank, and the cam in 4 pieces.
I had a rod snap at the wrist pin.. looked identical to that. Girdle got hammered by the rod.
