What are the best mods for a car with a stock motor and turbo
I was thinking Rear control arms, 50lb injectors, 93 chip, air fiter K&N, exhaust???
I would box the upper and lower control arms, get a ATR style rear swaybar, a TT chip and methanol kit. A downpipe will help a little, and a used front mount will help a little too.
Thats what i did in the car in my sig.
The hooker cat back exhaust system is a good upgrade, i have it on a few cars and it sounds great.
Details of the run:
60' 1.624
330' 4.799
1/8 7.483
MPH 91.27
1000' 9.80
1/4 11.767
MPH 114.62
RACE WEIGHT: 3595 WITH ME
BLOCK: Stock 109 Motor never been out of car
HEADS: Stock 8445
CAM: Stock
TRANSMISSION: Stock 2004R
TORQUE CONVERTER: Stock D5
DIFFERENTIAL: Stock 8.5 3:42 gears and stock axles
INTERCOOLER: Kenne bell
http://i103.photobucket.com/albums/m...n/100_0874.jpg
THROTTLE BODY: Stock, not even semi ported
RJC POWER PLATE: YYYYEEEEESSSSS!!!!
INJECTORS: Stock 90,000 originals
THERMOSTAT: ATR 160°
TURBOCHARGER: Stock 87 turbo regal, portmatched compressor housing to inlet bell
VALVE SPRINGS: Stock 90K originals
MAF: LS1 3.5 with Mark Hueffman cold air kit
DOWN PIPE: MPE Keith Mease 3" S.S. downpipe
EXHAUST: Nonexistant, just downpipe
FUEL PUMP: 340m with Kenne Bell hotwire relay
FUEL PRESSURE REGULATOR: Stock TTA 237, non adjustable
FUEL PRESSURE: 47psi
ALCHOHOL INJECTION: Yes, writeup about it here DIY- Junk drawer DIY kit, SMC controller, Sureflow pump,m-10, 1/8th ss line...
PROPAIN INJECTION: NO
NITROUS: NO
AIR FILTER AND AIR INTAKE: Mark Hueffman 4" to 3.5 at MAF
TIRE DESIGN, SIZE & AIR PRESSURE: M/T 28x9.0 ET drags at 12.0 psi cold
AIR BAG(s): 1 on pass side rear, 20psi
SUSPENSION: Missing front swaybar and endlinks, boxed rear uppers and lowers, air bag 20psi and ATR rear 1 3/8 sway bar
SCAN TOOL: Scanmaster 2.1
FUEL: Either 110 Turbo blue OR some type of Blue 112???
CHIP: TT Eric Marshall TT chip made at the nats for my grey car in 03?
CHIP TIMING: 27° in first and second 25° in third
KNOCK RETARD: .5 or 1.0 MAX entire run
OXYGEN SENSOR VOLTAGE: With SMC controller at 4, its 760's at 22-23psi
EXHAUST GAS TEMPERATURE: NO EGT
TRACK ELEVATION: LESS THAN 800 feet
TEMPERATURE: 55°
PEAK BOOST: 23
BOOST AT LAUNCH: 10psi foot brake
MILES ON THE CAR/ENGINE: 90,150 ish
