Little background just had an aparently half assed rebuild done about 5-10k miles ago and have been chaseing an oil burning issue and the machinist had put the umbrella seals that came with the new cam from comp in and they were riding up the valve guide so i replaced them with felpro's this caused it to smoke like a hell then i thought it could be the .1 shims i had to put in to get the proper preload (Stock TTA Rockers). so i installed .1 shorter rods and removed the shims this seems to have fixed the oil issue. But now she runs like crap so i had some exhaust leaks welded up, blms are better but but still misses, iac was a little high adjusted that and tps started pulling plugs and no change in idle when you pull number 6, I then checked the injector with a noid light it flashes so i assume its a bad injector 42# 009's. I wanted to go bigger any way so i order some 60# and a chip from eric but still no fix. replaced number 6 plug and still no fix the new plug is lightly caked black and oh btw the exhaust now reeks of fuel and im at a dead end any suggestions??
TIA
TIA
