Still have Questions
No Its still missing at 5600 rpm but I'm able to take it to the rev limit at 6200 rpm so I know its not the chip rev kicking in. I removed the MSD module from under the coil pack just to see if it was the cause.But it is still is missing after that.I'm also thinking that I may be 180 out on my cam timing.I read the tech stuff and It said to measure on a piece of tape 1.45 inchs I'm guessing thats almost 1 1/2 inchs I hope,Also I put it to the left of the top dead center mark on the balancer and then moved the balancer clockwise to that mark at 1.45 on the 0 mark on the plastic gage that tells you your timing degrees.And then rotated the cap counter clockwise until the ohm meter read 0.What I really need is to talk to someone that can walk me through the timming set up,So if anyone can help I would really appreciate it....Thanks Tony
This weekend I'm trying a different coil pack and module to see if that fixes the problem.
