But I don't care. This tranny I got is just not right. It's a non BRF tranny that I got pretty cheap. It shifts fine up to about half throttle. It's supposed to have a .500 tv valve, hardened stator, updated clutches, kevlar wide band and modified vavle body and a TransGo shift kit. It works good but it won't shift 2-3 without letting off the gas a little bit. I,ve adjusted the TV cable and that helped under moderate throttle but not WOT. I read that the governor and the valve body needs to be matched. Question is can I use these parts from my old BRF tranny in this unit?? They were in good shape when removed. Also if I remove the valve body how will I know where to put the check balls if I dont have direction from a TransGo shift Kit???
