Hello guys,
Iv'e got a gremlin uglier than my 1975 AMC. Its a miss 1 outta 3 times i punch it. And it is just when motor has been run for 20 minutes or so. Two weeks ago I had a full time miss under boost. Found a bad plug-that fixed it for about 6 days. Then i found an open (infinite resistance) plug wire. That fixed it for a day. Now it doesn't miss consistantly on each WOT just 1 outta 3 times.
I also have very inconsistant idle smoke. I have put in new valve springs and intake seals, less often but just as smoky when it does it. My turbo is new and I just removed it and vacuum test shows OK. I mention smoke because im wondering if it is related to miss. Plugs are not oily at all. Static FP=44, O2's are 790-850, retard not over 4, boost set at 16, usually run 18, and yes, turning it down seems to cut miss some. 93 octane. I am a GN newbie and just have my little Auto Xray 240 which Im hoping is giving accurate knock readings. Plugs are set @35. Reds wires are on the way. The car does have a periodic miss at idle and under a free 2000 rpm or higher it does miss fairly often. Coould that bad plug/wire have hurt module. The ohm test shows good on coil. HELP
