Methanol Life
03FatBoy
I have a Razor's kit in my GN. It is infrequently driven, shows, cruzin, fair weather, etc. How long will the meth retain it's "potency" or whatever you would call it?
Thanks!
if its liquid its meth , if its cloudy it contains water , still usable though
from website at http://www.methanex.com/products/faqs.htm
.What is the shelf life/stability of methanol?
Without interference from or interaction with external contaminants, methanol will not deteriorate or decompose, thus the shelf life would be indefinite. Problems arise if the product is not protected from exposure to contamination, including exposure to the atmosphere.
For example, methanol is very hygroscopic, i.e., it readily absorbs moisture. So if the product is open to the atmosphere, it will absorb moisture directly from the air.
Also, methanol is an excellent solvent, so it is very important that it be stored in a container of an appropriate material. For example, methanol will dissolve plasticizers in some plastics.
Properly sealed and protected methanol should maintain its integrity for a very long tim
