I have my Front cover off changing the timing set and was thinking of installing this Melling HV oil pump kit that I bought years ago and never used.
I did a search and read thru the post, but also read some critics of the plate.
I only have around 8lbs hot at idle and I can only find the highest pressure springs that came with the kit. Will this be ok?
Also, will it be ok to bead blast the cover while I have it off? If I just make sure to wash it very well afterward.
