G gnX405 Active Member Joined May 31, 2001 Jan 11, 2009 #1 Anyone here (Grumpy perhaps) familiar with the 2nd gen RX-7 swaps similar to MisRed? My question is, can a front sway bar be installed? I see that a non-modified sway bar runs in the same area as the crank pulley. Thanks in advance, -john
D Dave Levey Member Joined May 24, 2001 Jan 11, 2009 #2 It depends on where you position the engine, if you set the motor low enough to clear the stock hood the sway bar will not fit, if you lift the motor to clear the sway bar time for a custom hood,
G gnX405 Active Member Joined May 31, 2001 Jan 12, 2009 #3 That makes sense. In my case I have a stock TII hood (with slight rub) and therefore no sway bar. Thanks for the post. If anyone has suggestions for fashioning up a bar to fit, I'm all ears. I'm wodering if it is possible to make a bar with extra bends. -john
