Ill try to make this one more simpler since I think my last post was confusing.
After I take my newly rebuilt 700r4 on a good drive around the town, (warm it up real good), I stop with engine idling at about 650 rpm's , and put it into manual 1st, my pressures read 70-90psi.
When I first start out and do the same thing but with only 5 minutes of driving my pressures read 210psi in M1.
Is it just because the idle is low when warm? and I have idling higher when its cold to keep prevent the engine from dying?
Doing a standard thorough pressure check the pressures all look good
Does this sound ok?
Does this sound ok?
