One advantage.. you can't get the old MAF anymore from GM. All that is available are aftermarket "equivalents" and some are more equivalent than others. Seems to be a bit of trial and error in getting one that is correctly calibrated for a turbo 6. With the Translator, you have options, and there is additional tuning capability, as well as the ability to measure air flows above 255gm/sec, if you run more boost than stock.
