Can a bad maf cause the car to stall once in while? After the car is running for a minute or so it wants to almost die when I put it in gear and when it gets hot it stalls once in a while. I have my scanmaster hooked up and looked at all the sensors and appear normal even maf settings. I also reset my iac and still no luck.
It will idle fine one minute then like crap the next minute. I can't find any vacuum leaks either.
fp 43 line off
blm 115-128
int 128
af 5-6 idle
tps .46 idle
iac 25
fp 43 line off
blm 115-128
int 128
af 5-6 idle
tps .46 idle
iac 25
