DONE the search.....found limited information on pros/cons of installing the 3.5 MAF on the up-pipe near/close to throttle body.
ADVANTAGES:
1.better driveability.
2.does not go rich when backing off the throttle at high boost.
3.quickens throttle response/gives more accurate MAF readings since its located closer to the engine.
DISADVANTAGES:
1.the maf sensor wire does get red hot and "IF" ALKY spray---BOOM!!!
2.seals blowing out on the compressor side causing the MAF sensor to be contaminated.
3.MAF sensor's internal coming apart and going thru the throttle-body
ASSUMEING all is correct....... what distance is best:
1.Distance the MAF is located from the throttle body?
2.Distance the MAF is located from the Alky nozzle?
THANKS for the Help and the reply
ALSO, hoping everybody had/having a GREAT CHRISTmas!!!!
ADVANTAGES:
DISADVANTAGES:
