those arent mafs they are just the ends ..no sensor
and you dont want to change the ones on a factory LT1/Ls1 maf sensor with ends for more flow because it will no longer read air flow correctly
if you are on the stock 85 maf /ecm you cant just swap in a lt1/ls1 sensor
you have to convert your system over to an 87 ecm + appropriate chip and then you can run a maf translator and conenct an lt1/ls1 maf
if you are on the stock 85 maf you cant ust run a lt1/ls1 sensor
