low oil/choke light with girdle?
liv4gnz
i just saw the this light flash going around and uphill turn, it came on for like a second and went off, the first time i immediately pulled over and checked the oil and it was above the add line and i am using an rjc girdle with the pick up extension, oil pressure never missed a beat, im thinking it came on since the pan is dropped and around a turn ir sloshed to one side for a moment, any one else experience this before?
It comes on when the oil pressure is < 4PSI, what does your gauge say?
my gage has never read less than 15 idle, maybe burning hot itll be like 13, cold its about 75 with 15w40, its definately not a pressure problem, only when i went around a turn it came up for a split second and went away, would a loose air temp sensor set it off some how related to the choke part? it wiggled loose since the connector was broken...
When they go bad they can light up intermittently, then they start to leak after a while.
