Low Mileage Power Train & Other Parts....
Greybeard
I’m building a V8 conversion car, and next week I’m disassembling the donor. The donor car in quesiton is a 18,750 mile (not a typo – real miles) 1986 T-Type. Parts are stock unless noted. Parts are on Vancouver Island, BC, Canada. Can ship most, but big items are likely best picked up. Initially, I will have the following pieces for sale:
(1) turbo V6, no accessories (has adjustable fuel PSI reg, no other visible mods); runs absolutely perfect and no leaks - $2850
(2) engine management system (computer – has been chipped, but don’t know what it is at the moment) - $150
(3) injector harness - $50
(4) V6 engine mounts & frame mounts - $25
(5) 200R4 transmission - $500
(6) torque converter - $150
(7) torque converter dust cover - $10
(8) transmission dipstick & tube -- $25
(9) flex plate & hardware - $35
(10) starter & hardware - $50
(11) hoses – power steering, a/c, misc. - $15
(12) transmission crossmember & mount – $40
(13) driveshaft - $50
(14) trailing arms, stock - $75
(15) air conditioning compressor - $100
(16) air conditioning evaporater & heater (box @ firewall) - $100
(17) air conditioning drier - $50
(18) air conditioning condensor - $50
(19) air conditioning controls (digital) - $200
(20) cruise control - $75
(21) cruise control, spare - $75
(22) engine accessory pulleys & accessory brackets - $100
(23) aftermarket crank pulley - $25
(24) center console (maroon) - $100
(25) shifter, complete with cable - $75
(26) hood, no latch or spring or rear trim, but with emblems & hood pad (gray in color, small dent at nose, likely from closing) - $250
(27) fuel lines & clips - $10
(28) Power Master (brake booster & master cylinder) - $150
(29) power steering pump - $50
(30) power steering reservoir - $15
(31) brake lines with clips - $15
(32) radiator, bare - $250
(33) electric fan assemblies with shroud – $75
(34) intercooler assembly, complete w/ shroud & brackets - $150
(35) intercooler fan - $25
(36) evaporative emmission system (complete) - $15
(37) exhaust system, Hooker, complete (appears as-new, no catalytic converter) - $200
(38) GN lug nuts (19 only) - $10
(39) air intake system, K&N - $35
(40) stock air cleaner box assembly (appears to be new car take-off) - $25
(41) transmission cooler lines - $20
(42) auxiliary trans cooler (Art Carr) - $55
(43) luggage compartment carpet assembly - $50
(44) VDO gauges (oil psi, boost, volts, water temp w/ bracket that mounts under dash, over console) - $150
(45) power antenna (was unplugged – likely doesn’t work) - $30
(46) billet thermostat housing (new) - $15
(47) spare fuel filter (new in box) - $20
(48) Bosch (stock) fuel pressure regulators X2 (appear NOS) - $25 each
(49) engine ratchet tie down - $20
I’ll have more parts available later (rear axle, suspension, T-Type wheels, etc.) as the project progresses. Thanks for your time. Please call or e-mail for more information (PM's work too, but I monitor my e-mail regularly).
Wayne @ 250-743-9363 (West Coast)
Restorer@shaw.ca
K&n
Is the K&N a cold air kit (filter down behind bumper) or just the filter? thank you, paul
Fuel Lines
Are these the ones from the frame to the fuel rail, with the flex line on them?
If so I will buy them.
Parts
If not sold put me in for #38,#40. I live in IL.60402 Let know a total.
Also if you have an intake laying around for 86-87 let me know Thanks,
Forrest
