I just installed a JMB fender well intake from the W body store on my dads 98 regal GS. It sound sweet as hell but he's only making about 6 pounds of boost now and he already installed a smaller pulley on the blower it made about 11.5 psi with horrible 98 air box. Does the computer need to learn that the motor is now getting more air if so do I drive it around for awhile or reset the computer. Helpful info when I installed the new intake I also changed the fuel filter (which was orginal or changed at the dealer in the 2 years before my dad bought it) and I changed the vacuum line from the top of the blower housing to the bypass valve. I know its not giving a false reading because I can smoke the crap out him in my 91 lumina Z34 with a 5 speed and when he had the stock box it was dead even.
what size pulley did you put on it ?
what is in place for exhaust mods ?
it is not uncommon to put on a smaller pulley and make the car slower if there arent enough exhaust mods in place to support the pulley size
basically it will knock and retard the timing to try to save the pistons.
Many a piston has been chipped by throwing a 3.4 or 3.5 pulley on a car with stock manifolds and exhaust still in place
an intake exhaust ,tune car will crack 13's on the stock pulley
so a z34 is beating it now and it didnt before ?
it sounds like in your case it is dumping boost , first check that vacuum line you said you had your hands on - it could be self inflicted , did it start dumping boost that day ?
I havent messed with it but you can probably disconnect the boost bypass solenoid and get full boost - you should be able to disable the bypass function and see full boost i just forget if you unplug the sol , or plug the vac line to make it happen
you could also adjust the placement of the boost bypass valve to increase or decrease its sensitivity , it is adjustable
boost #s on these cars are decieving since restricted exhaust flow will cause boost stacking either through poor flowing components or from knock retard and torque management combining for sooo much timing being pulled that valve timing doesnt empty the blower quickly enough and it stacks
2 3.5 pulley cars one sees 13psi and one sees 10.5 psi the one seeing 10.5 psi will be faster 9 times out of 10
