Here are my scan master readings
Af 6
Lb 32
Int 128
Bl 110
Ats 136
Tps 44
Iac 22
The problem I'm having is at wot the scan master reads in the mid 600 mv. Cruising the bl's are at 117 on a flat road at 65mph. Fuel pressure is 43 psi with line off. Car runs perfect until I go into wot, then it's extremely lean! Fuel pressure goes up 1 lb for every pound of boost as it should. Maf doesn't lock at 255 but does go up to 250. Any suggestions? Thanks Ron.
Af 6
Lb 32
Int 128
Bl 110
Ats 136
Tps 44
Iac 22
