H hang10 old surfboards wanted!!! Joined Jul 19, 2001 May 6, 2009 #1 Lost the bolt on that holds the ground wire from the battery at the lower turbo bracket....what size is that sob ?
D Dwayne Narrow A$$ Racing Joined May 25, 2001 May 6, 2009 #4 Can't you measure to see how long it needs to be ?
H hang10 old surfboards wanted!!! Joined Jul 19, 2001 May 6, 2009 #5 well if i had the missing bolt i could measure length and thread pitch,,,,,,,,,but then i wouldnt need to replace it..........
U UNGN Can't Re- Member Joined May 24, 2001 May 6, 2009 #6 Its supposed to be a stud M10-1.5X20 P/N 14101259 but an M10-1.5X20 or 25 bolt will work, too.
1 1quick6 Shadetree Mechanic Joined May 24, 2001 May 6, 2009 #7 Just looked at my engine diagram to verify that it is indeed M10x1.5x20
