Looking for center caps and lug nuts for 16" Classic Industries wheels
Wheels nuts with caps and wheel centre caps
New/as new or a link to where I can order them would be great.
Thanks,
Tom
You can get both of these from Dennis @ Kirbans, that's where I got mine.
You'll need the trans am centre caps #7012 &
GNX-Style LUG NUTS, BLACK PLASTIC CAPS and VALVE STEMS SET (40) #7073 :biggrin:
WHEELS and RELATED PARTS
Also had Mark Hueffman at TR Custom Parts make up some nice Turbo 6 custom wheel cap overlays to replace the ones that came with the caps originally.
You should also be aware that you will require the metal inner assy that goes in each centre cap. These will grip the aluminum wheel centre amazingly and help hold the cap on to the wheel as the plastic teeth on the wheel caps are not enough to hold alone (especially on the fronts, due to heat from front rotors warping and distorting the plastic teeth). You will eventually loose them!
I know this from experience. :eek:
dave
