I have a set of 30# Accel injectors that the P/O had installed. Ever since I've increased the breathing by swapping to an open element air filter, I've run lean. I've increased the fueling within my TT chip & then increased the base fuel pressure to 45#, yet I'm still lean on my O2 readings & my plugs look white.
I need to have a new chip burned to work with some other changes that I've made & I'm thinking of ordering a set of 60# injectors along with it. How far will the 60's go? Is this the largest set of injectors that a single Walbro can supply? Does it look like I'm headed in the right direction with ordering the 60's, or am I overlooking something?
Thank you
~JM~
Thank you
~JM~
