So if i'm reading your data correctly it means your running after using the alky 25 degree's timing at 5200 rpms at 25 PSI. From 20 degree's before. So its an increase of 5d-6d depending on RPM at 25 PSI.
Now using straight methanol will richen up your mixture. And to be scientific.. we needs to know what concentration of alcohol is present in the "mix"
What are you basing performance numbers while testing? Just a general seat of the pants or is there any datalogging happening? Are you doing this with a WB? And then tried different AF ..
This was on the 7749 ECM as well correct?
Also as you increase timing shouldnt the EGT drop? Especially with alky.. but using the water mixed in is probably why its reading higher.
Guess your not anticipating going over 5200 and 28 lbs of boost
