yeah , autometer makes some ,but they aint for shallow pokets, $185 for 0-100 electric sender and gauge style or if you go mechanical youll need the mechanical 0-100 gauge and the isolator which then makes the mechanical setup almost as much as the electric
check summitracing.com for available gauges
the autogauge are fine but as for accuracy they arent as good on tolerences (accuracy) as the autometer line , but on a budget they will suffice
when it comes to gauges if you cant trust them to be accurate they are useless , i run the autometer sportcomps which are the cheapest of the autometer line , i have vdo cockpits in my other car as a GNX gauge cluster which are about the cheapest gauge from vdo but the accuracy and ability to read values with the indicator graduations , limited needle travel and narrower range make them ok but not any way near as reliable as the autometers
