I just installed my rear 1/4 windows and test fitted my t-top weather strip. One of the 1/4 windows leaks but only in one spot. Can I do a spot fix on that one place by squishing some sealer up from the inside of the car or do I have to take the window out and try again? Also the t-tops sealed real good in the back, but I still have a steady stream of water coming from the holes where the sun visors are supposed to go. (the interior is all apart right now) I have determined that the water is not coming in past were the top meets the seal but where the seal meets the windshield cross bar. But I don't think that the seal is meant to seal between them 2 surfaces. I think the water might be going through some holes that are there from the factory?? Anyone have any ideas on these problems? Will the leaks go away after I put some adhesive up there?
Thanks,
Thanks,
